Where to mount the speedo on T's
Old 12-31-2014, 10:08 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,514 Likes on 2,134 Posts
Default Where to mount the speedo on T's
I want to put 8" t bars on my '08 FXD. It currently has a single gauge on a bar mounted bracket with integrated dummy lights. I'm looking for a better way to mount the speedo and lights without using the stock mount. Too bad I don't have the tank mount gauge, as that would solve it. But I've got to find something that will mount to the t bars, but I don't want it above the bar like it is now.
Any suggestions?
Tx
Old 12-31-2014, 10:35 AM
MGregg85's Avatar
MGregg85
MGregg85 is offline
What brand tbars are you going with? Most of the makers offer some way to mount your gauges, most will weld on bungs either high or low for them. Some companies sell clamps that mount to the riser portion and can slide up and down so you can position your speedo.
Old 12-31-2014, 10:40 AM
PoCoBob's Avatar
PoCoBob
PoCoBob is offline
I believe these will work depending on how high your bars are. You may be able to put the speedo above the tank in the inside of the bars.
http://www.accutronix.com/p/risers/b...parts/166.html
Old 12-31-2014, 11:20 AM
monster715's Avatar
monster715
monster715 is offline
Yea the accutronix mount is what I use. You need to pick up the single gauge mount from Harley to go with it tho
Old 12-31-2014, 11:28 AM
Mchad's Avatar
Mchad
Mchad is offline
I'm going low. No higher then 8" prob. Have to work within the limits of my current cables as well. The bike has low bars on it now. See photo. Also, the current config has the control wires on the outside of the bars. I'd like to run them inside if possible, without having to extend them. I'll have to see how much slack there is I guess.
I see what you mean. the current gauge is also the clamp for the bars. So that'll have to be replaced for sure.
Old 12-31-2014, 12:02 PM
sonnydaze's Avatar
sonnydaze
sonnydaze is offline
just used frame oil line clamps they cost like 11 bucks and come in 1 inch 1 ,1/4 , 1 1/2
Old 12-31-2014, 01:59 PM
monster715's Avatar
monster715
Yea you could use cable clamps too if you want to save some money. Still gonna have to get the single gauge mount for the sportsters
Old 12-31-2014, 02:04 PM
Mchad's Avatar
Mchad
Mchad is offline
Still familiarizing myself with this bike. What would I do with frame oil line clamps and a speedo?
Old 12-31-2014, 08:25 PM
evil-1's Avatar
evil-1
evil-1 is offline
I mounted mine the same way as Sonnydaze. The frame clamps work great. Mount one on each riser portion of the bars and bolt on your speedo. Simple.
Old 12-31-2014, 08:35 PM
sonnydaze's Avatar
sonnydaze
if you need a single gauge mount off a sportster pm me I have one I don't need , actually its a road king tach mount but its same thing
Quick Reply: Where to mount the speedo on T's
