stage 1 fuel miliage
hey guys just curious here i took my street bob out out some miles on it just curious what people are getting to a tank i think im clocking about 150 from full till fuel light. I have a stock 103 with thunderheader SE AC and PCV from fuel moto. i do a mix between freeway and in city
I noticed a big hit in fuel mileage in the winter mostly, combined with stage 1, and wind protection. I also have a Range of 150 or so when I fill up. I do a mix of freeway and city as well, then my mpg goes up quite a bit just cruising back roads. I havent had my full stage 1 out in warm temps since I put it on in January. But with pipes and a tune in the summer I would average 39-40mpg
I have a 2009 Dyna Super Glide. It has a Stage-1, 551 Easy Start cams but not much else done to the motor. I get around 48 to 51 mpg during the summer when the windshield and vinyl lowers are not on the bike. In the winter, with a tall Memphis Fats windshield and hand-guard extensions and Desert Dawgs lowers, my mileage falls off to around 42 mpg. Just about everyone that I know complains about winter mileage being less than in the summer. If you live in an area with seasonal blends of gasoline, that could be a factor, though I read a while back that winter blends should produce better fuel economy.
If you have tuner on your bike, it can really cut your mileage if it is either not set up correctly or if you have a motor that can handle a high-fuel/air intake volume.
AJ from Open Road Cycles in Denver, NC can configure a tuner to deliver either extended range or maximum performance, depending on what you want. He has one model that will let him adjust these parameters on the fly.
Pete
Pete
There is a difference between winter and summer fuel. Better mileage with summer blend. Read your manual on the back of your speedo is a button press it it will tell you how far you can go at full, or how much you have left in millage. Me I don't give a **** about mileage I just ride.
