Need advice for mechanical upgrades
The bike is an 01 fxdxt. I just sold my jap bike so I'll have some cash to mess with the dyna.
Anyway I do a lot of riding to and from work on a major interstate. Im usually doing 65 because when I get up to 70-75ish I hardly have any roll on torque.
I'm wanting to do some upgrades to the bike that'll let me do 75 comfortably.
Bike has a custom exhaust and a open k&n ac
Other question is that i was looking at big bore kits etc and saw s&s has a 107. Would that even fit my frame? and is there any way I can save money when boring out the jugs or buying bigger ones in regards to part interchangeability?
Unless you bore out your cases or go to a stroker set up(longer connecting rods), I believe the S&S 97" kit is as big as you can go. With the right cams, I think it would satisfy you completely.
Also recommend posting this question in the Tech & Mech > Engine Mech area of this Forum - a lot of smart engine types moniter, although a couple just want your $$....
Where in Texas? I know of one really good shop in the DFW area.
I'm not to familiar to the grease monkey language lol. What does going to a striker entail? And are there any good cams I could put in with the stock lift? The one I was eyeing was the s&s 583 but I'm guessing I'd still need some modifications to run it.
Right near Houston.
I think the 583 cams would be too high of lift for your stock cylinder heads - again, several of the guy in the Engine Tech Forum would know exactly. But know this, you can always get new springs installed in your cylinder heads if you want to run higher lift cams. Everything boils down t $$$, need to determine your budget then you will be able to determine what to do.
Those 583 cams "hit" in the low rpms, good for burn outs and quick off the line, but I think there are better choices for a dyna. I would think S&S 510s would be a good choice as a bolt in for an 88"er.
Here is what I would do if you got about $2500: S&S 97", basic headwork ~$600, cams(Andrews 54 maybe), lifters, adj pushrods, dyno tune, plus all the gaskets/oil/tools etc. If you pay somebody, probably about $1000 more.
With a stroker upgrade you install slightly longer rods that attach to your pistons and thus a longer stroke and bigger cubic inches with the taller cylinders that will go with the upgrade. Gets very pricy, so I would not worry about it unless you really want to go big.
jmb79
10-21-2013 08:30 PM
