Handle bars movement
Old Oct 1, 2015 | 02:00 AM
N1265's Avatar
N1265
Default Handle bars movement
Hi Guys,
New to the FLD, are the handlebars suppose to move from front to back ? seems like they are mounted in rubber bushings but I do not know if this is normal.
Thanks,
Old Oct 1, 2015 | 02:35 AM
66cruiser's Avatar
66cruiser
Poly bushings will cure that.
Old Oct 1, 2015 | 02:47 AM
DonN's Avatar
DonN
Yes on the poly bushings. If the bars are slipping in the clamp, can wrap some emery cloth to stop the slipping.
Old Oct 1, 2015 | 12:02 PM
N1265's Avatar
N1265
They are not slipping in the clamp, Just move forward and backward when you pull on them. I figured Harley mounted them in rubber ( somewhere in the triple tree ) to cure vibrations going to the hands but was not sure if this movement was normal.
Do you guys notice any more vibrations with the poly bushings ?
Is this a Mod that you guys did yourself or does it require special tools ?
How much are the poly bushings ?
Many Thanks,
Old Oct 1, 2015 | 01:21 PM
jaxdwg's Avatar
jaxdwg
Originally Posted by N1265
Hi Guys,
Thanks,
Before going through all the bs, try tightening the mount nuts a bit first and see if that fixes the problem
Old Oct 1, 2015 | 01:24 PM
jaxdwg's Avatar
jaxdwg
The problem with the poly bushings is that, yes, they will tighten things up, but you will feel more vibes in the bars. I opted to go back to stock because mine were cracked out, and haven't looked back
Old Oct 1, 2015 | 02:05 PM
thephatboy2003's Avatar
thephatboy2003
I have the same movement in my bars. I went to the Poly Bushings but still have a lot of movement from front to back. The thing I always check on, and have had to adjust once so far is movement when pulling upward. That happened and it told me that I had to tighten the riser bolts. Torqued them to the proper setting, still had the front to back movement, but no upward pull type movement.
Old Oct 1, 2015 | 02:25 PM
SHORTY 13's Avatar
SHORTY 13
I run polys with 12" burly bars and they did firm up everything a little. If you want no movement then you will need to look at solids.
I didn't notice any increase in vibes with polys.
Old Oct 1, 2015 | 08:04 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The factory rubber bushing are made to give and move a little bit, not a lot, but a little to help with vibrations.
Old Oct 1, 2015 | 08:17 PM
Racqueteer9's Avatar
Racqueteer9
I put poly bushings in and didn't notice very much difference. I think it's psychological for the people who say it's a world of difference between the rubber and the poly, they both flex a tad.
