Street bob fender swap info needed
Old 02-06-2016, 11:05 PM
gartec81's Avatar
gartec81
gartec81 is online now
Default Street bob fender swap info needed
Swapping fenders
Just purchased a 2008 full rear fender that I want to replace my street bob fender
Wiring...
Any link to part number for what I need to run a regular tail light that's on the low riders?
It's a 2015 can bus system. I need what clips in under the seat and runs to the tail light
Also..,
Options for led lay down tail lights for canbus?
Old 02-06-2016, 11:17 PM
gartec81's Avatar
gartec81
Is this the Harness for rear brake light/turn signals
Old 02-07-2016, 08:09 AM
craigffb's Avatar
craigffb
craigffb is offline
Old 02-07-2016, 10:04 AM
gartec81's Avatar
gartec81
That's a perfect link. I'm still unsure which tail light harness I need thought
Is it #27?
Old 02-07-2016, 10:06 AM
gartec81's Avatar
gartec81
Also looks like to get a dual gauge set up going would not be that expensive
Would want dual gauge on the handlebars
Old 02-07-2016, 11:17 AM
AdamM's Avatar
AdamM
AdamM is offline
Yes 68770-02B the correct harness. You also need the new version of the chrome tail light base. I'll try to find the PN for you
EDIT: 68066-99A is the base
Old 02-07-2016, 02:00 PM
gartec81's Avatar
gartec81
This is what the fender comes with
Will this base work with a custom dynamics tail light?
Old 02-07-2016, 02:16 PM
AdamM's Avatar
AdamM
AdamM is offline
Unscrew the actual light from the base, the base you need has connectors attached that the harness, blinkers and tail light plug in to. If it doesn't have those then you need a new one. You said the fender is from a 2008 so I doubt its the right one
Old 02-07-2016, 02:52 PM
Chad1200's Avatar
Chad1200
Chad1200 is offline
b2inUT posted his parts list awhile ago which was also reposted by SquidHead. I used the same list to do the swap on my 2009 Street Bob with a 2006 Low Rider fender I scored on eBay. I also used the Custom Dynamics LED tail lamp and had no issues fitting it to the H-D tail lamp base. From looking at your pictures, I know you probably have most of the parts already but more info is always good right?
Either way, here's the list and his comments:
Harley parts:
59634-06DH FENDER, rear (vivid black) (eBay - used)
3022A SCREW (holds base to fender) (HD dealer)
7964 NUT (clips onto tab on fender, 3022A screw goes through base into this) (HD dealer)
68066-99A BASE ASSEMBLY (stock tail light base assembly for many models) (HD dealer)
68026-99 SCREW (2) holds light to base. (HD dealer)
68770-02B HARNESS ASSEMBLY (replaces stock wire harness. connects under seat, adhesive backing to stick it to the underside of the fender and runs to the tail light base) (HD dealer)
Non-Harley:
Custom Dynamics Black LED Integrated Laydown Taillight w/ Turn Signals & Window (P/N: GEN2I-LDW-S-B) (eBay)
Kuryakyn Curved Laydown License Plate Frame (P/N: 9171 Chrome, 3148 Black) (eBay)
I’ve heard the Drag Specialties costs less and lays down more.
I replaced the rear turn signal strut/stalk bolts with some stainless 5/16” x 1 1/2” bolts, washers and nuts. I think I can get away with a 1” length, however. (Home Depot)
In another thread, somewhere, I found this link that shows all the original HD parts and numbers.
http://www.granitestateharleystore.c...R%7c%7e1%5cGV4
Old 02-08-2016, 08:05 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Looking at the part numbers and based on HD logic (the -XX in the part number is the last year it was last updated), if you have the circuit board already in the light housing you should be good, it was last updated in 1999. And the harness 68770-02B was last updated in 2002. So you should only need the harness to go from the seat to the tail light. Also, you might have to rewire or rebuild you turn sigs connectors because they will be going into the light housing for power and not under the seat. You'll have the harness going from under the seat to the main tail light and the sigs branch out from there. Not sure if removing the STT module under the seat will make a difference (if you have one, not sure if the canbus system uses one), removing it might only make your sigs just sigs and not additional run and brake lights.
Quick Reply: Street bob fender swap info needed
