S&S 106 kit with 510g cam kit
take a look at the Feuling 574, I had that installed along with the S&S 106 and a 2-into-1 and it was like a different bike... pulls real strong off the line without being hard to manage, i've passed a few vehicles like they're going backwards too.
I haul camping gear for days as well as rip around town, suited me perfectly.
chain drive still...
I think the oil pump spring was changed, and my mech suggested that we do the cam chain tensioners and tappets while we were in there as there was already a few miles on the ol'girl
S&S tech support said theirs is a drop in kit. Nothing else needed.
That and that I was offered a 510g kit for 499 shipped was the thing that got me motivated.
My bike is still new at 30k miles. Runs great. But I will putting some miles on her this year. And I don't want problems especially when I will be far from home.
on their website the 510s are described as:
"Designed as a bolt-in cam for 88, 95, and 96 CID engines with compression ratios below 9.7:1, it is primarily intended for use with stock, un-ported heads. 3000-5500 rpm. Bolt-in overall"
With the 106 kit you'll be up at 10:1 CR
And I could be wrong but 3000 RPM might be just a little high for passing power
If you do go w/ an S&S 106 I would recommend their 585 cam or higher along w/ some headwork. I definitly wouldn't install that tiny 510 into your dyna.
EDIT:
On a stock crank I personally would never go gear drive.
Listen to what HD Bobber said. You can't install that gear drive cam without addressing your crank, and that's big, big $$$. The 'horror stories' of chain drive don't apply to late model bikes. I've been into my camchest numerous times and not once have I seen any cause for concern from my chain tensioners.
I ran an Andrews 48H cam and 30T power pulley until this winter and it has some serious get up and go.
[QUOTE=HD Bobber;14923349]Seems to me like you don't want to do headwork just big bore and cam. Also from what you're describing it seems like a nice Andrews 48 cam swap and maybe a gearing change would be plenty(30/70 or 30/68 combo). This way you can save some real coin and put a smile on your face every time your crack the whip. Good fuel tuner and 2:1 is the icing on the cake....
I have the Vance and Hines fuel pack on now. An Arlen Ness stage 1 air kit. Running short shots now, will be switching to a TBR or Thrasher or RSD stainless 2 into 1. Saving money is a huge plus.
Could I do the cams now and the 106 upgrade later? I would like to hold off on the 106 till about 100k miles, but I sure would like more low to mid power now.
In doing the gearing change would that still leave me a good cruising speed. On open roads I tend to cruise along at about 80 to 90 mph. Most of my life sadly, is spent daily riding through stop and go traffic in LA. But I will be making some 1k longer trips this year.
Thanks for the replies. Your info is not falling on deaf ears. I just want to ride this year and travel worry free.
