Oil level check after oil change on '06 Dyna.
JayStronghawk (05-08-2016)
Joe is right. You can suck some out for peace of mind.
3 qt too much. 2 to 2.5 is the average.
Cold oil check, make sure it's closer to the lower level cause once it warms up it'll jump half way up the dip stick or more.
I'm surprised so many people keep making the same mistakes when oil changing. It's like the 3rd thread I've seen this month or so with the same issues.
Received 5,388 Likes
Well maybe if HD printed the proper amounts, people wouldn't overfill. Anyone who has ever worked on a motor knows it's never totally dry unless torn down, so why even print that amount. Maybe someday they'll get into the 21st century and give us an oil glass window, using a dipstick is archaic and messy. I'm all about keeping the classic looks and styling, putting a dipstick on a cap next to a smoldering hot pipe is just a crappy design.
Baster doesn't work alone, won't reach down there. I used a couple feet of clear tubing at the end of the baster and sucked enough out to make it right. Thanks for the tip. Next time I'll start out with less and add later.
