Rear rotor off center...bearings?
I noticed recently my rear brakes making noise, assumed pads were worn, so I ordered a new set. Replaced the pads and rotor, and it still was making the grinding noise. On further inspection, the inside edge of the rotor is rubbing against and grinding into the inside edge of the caliper bracket, which somehow I didn't notice when I replaced the pads & rotor. I had the rear wheel off over the winter, and before that last fall when I replaced the rear wheel bearings and tire. Since I'm pretty sure that I couldn't have the spacers or caliper bracket installed incorrectly, and the rotor is a stock bolt on replacement, I'm guessing that when I installed the wheel bearings the hub is now not centered correctly--a millimeter or 2 towards the primary side, which would move the rotor over enough to rub the bracket.
I replaced the bearings using the Pit Posse puller/installer, and followed the procedure in the service manual.
Is it even possible to install the wheel bearings off center? I don't have any other guesses, but I thought I'd ask before I pull it apart.
Originally Posted by JustOneDean
Could be a warped rotor. I don't know how warped it would have to be to rub the inside of the bracket, though. Lay a straightedge (something you know to be truly straight, not just a wooden ruler) on the rotor and see if you can get a feeler gauge between the straightedge and the rotor.
There's no issue with pushing the brake side bearing deeper (assuming it's not bottomed), but technically you shouldn't re-use any removed bearing because the removal method compromises them. Some methods worse than others...like Slide-hammer removal...no bueno for reuse . Non impact removal like the pit posse = less possible damage, but still wouldn't be recommended.
That being said, I'm sure people have done it
That shouldn't stop you from going ahead with the plan, you'll know if it is solved and then decide if to buy 1 bearing
Without having the manual in front of me to read how its actually worded, I definitely would have assumed the primary side referred to the side the primary chain drive and belt drive pulley is on. Its possible that I misinterpreted the manual and installed the pulley side first, which would explain why the rotor side apparently isn't pressed in far enough.
