Steering stem help
I am scratching my head thinking you have the top tree referred to wrong. Post 3 is correct and that bevel on the adjuster fits in the bevel in the top tree. When you torque the top nut on top of the tree, that bevel locks the adjuster. The bevel in the top tree goes down toward the adjuster bevel. That 1111 should not be seen when the tree is on bike when you look down at the bar.
Recall - when you tighten that castle nut - it put preload on the bearings - not a lot.., but enough for the fall away setting
That bevel (I believe) is to focus that preload
The steering nut just holds..., and locks it all together - and of course keeps the stem from falling out
When it swivels - it does so as one complete unit
Ghost
Ghost
Lol, dont worry im past that point lol. So heres where im at, the star nut in the picture is correct?
The top tree goes flat side down? Which makes the beveled part on the tree useless as far as i can tell
Try putting it together and see if it works / looks right
But don't tighten till your sure
Ghost
Ghost
