Forward controls on a 2017 Street Bob
It is not absolutely necessary....There are threads on here on how to cut the shaft from behind the primary to allow you to get it out of the way.
https://www.hdforums.com/forum/dyna-...g-primary.html
I couldn't get the shift arm off of mine without pulling the primary on my 15 Fxdb or 17 lrs. I know others have, but there just wasn't enough room for me on either of my bikes. Pulling the primary really isn't that hard at all. You're definitely going to want a service manual, and obviously follow the torque specs. You'll need the primary locking tool from HD, but it's only about 20 bucks.
on my Fxdb, I tried just installing the forwards with the old shift arm, and left the shifter shaft (the one that goes through the primary) there. It worked, but the factory shift arm is shorter, so it was almost impossible to find neutral. I had to slightly rev the motor, and could only find neutral from second.
The he way I see it, if you can PAY somebody to do something, you can LEARN how to do it. There's a good video on YouTube on disassembling the primary, I think it's on a road King, but it will be very similar to what you're doing.
Aside de from hand tools, you'll only need the primary locking tool, and a t-70 torx socket. I found the t-70 at advanced auto but nobody else seemed to have it. If you're mechanically inclined, you could probably have the whole thing done in a hour. I'll see if I can find the YouTube video I was talking about.
You can do this without cutting.....or removing the primary.......I chrome capped the outer shaft stub and locked the inner shift arm with a special bracket....there are pictures at this thread....let me know if you have any questions, glad to help
https://www.hdforums.com/forum/gener...versation.html
Hi,
I have a 2017 Street Bob and just added the HD forward control kit that comes with the cap for the shaft and the bracket for the shift arm, but I have run into another problem I am hoping someone here and can help out with. The new linkage and shift arm on the forward controls seems to be just a tad short. The shift arm hits against the front of the primary case and I have trouble shifting to 2nd gear about 70% of the time. All other gears work great, 2nd is the only problem. It is definitely hitting the primary as I can see it when I operate by hand. There doesn't seem to be any way to adjust anywhere...hoping someone has an idea before I head up to the dealership.
Thanks
Thanks
hi,
i have a 2017 street bob and just added the hd forward control kit that comes with the cap for the shaft and the bracket for the shift arm, but i have run into another problem i am hoping someone here and can help out with. The new linkage and shift arm on the forward controls seems to be just a tad short. The shift arm hits against the front of the primary case and i have trouble shifting to 2nd gear about 70% of the time. All other gears work great, 2nd is the only problem. It is definitely hitting the primary as i can see it when i operate by hand. There doesn't seem to be any way to adjust anywhere...hoping someone has an idea before i head up to the dealership.
thanks
thanks
Harley Davidson Dyna Gear Shift Linkage
https://www.harley-davidson.com/shop...cted=category3
eBay Dyna Gear Shift Linkage
https://www.ebay.com/sch/i.html?_fro...lh_titledesc=0
ltcurt33
08-09-2020 10:55 PM
tdw
03-16-2017 07:59 PM
