Shade tree mechanic
Old May 10, 2010 | 08:14 AM
Cowpokey's Avatar
Cowpokey
Default Shade tree mechanic
Forward controls are not for you. I just got mine put on me Street Bob, not saying you can't do it....but you'd be much better off paying to let someone that knows how take care of it.
The whole primary has to be removed and reinstalled. Let a shop do it, you've been enlightened.
Old May 10, 2010 | 08:21 AM
davidnewtonparr's Avatar
davidnewtonparr
One of my favorite avatars...
Old May 10, 2010 | 08:42 AM
jstreet0204's Avatar
jstreet0204
You don't need to remove the primary. You can cut the mid shifter lever and slide it out.
Old May 10, 2010 | 08:52 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I did mine. Nothing to it.
Old May 10, 2010 | 09:28 AM
apethtel's Avatar
apethtel
I put mine on myself. I would recommend following the directions and pulling the primary. It was a little more than I thought it would be, but it can be done.
Old May 10, 2010 | 09:57 AM
clowe's Avatar
clowe
where do you cut at? I just put a set on my fxdx and didnt relize that until I was in to it. I thought it just went on the lever kind of like a sporty. for the time i just put a piece of saftey wire on the lever and a bolt until I could pull the whole unit.
Old May 10, 2010 | 10:11 AM
jstreet0204
behind the primary. I attached a hacksaw blade to a jig saw to speed up the process and accessed it from the bottom. Once its cut it slides right out saving yourself a huge amount of time, effort, and chance of messing something up by getting into the primary. Only draw back is you'd need a new lever if you decided to go back to mids. I left mine in there for a while before deciding to cut it.
Old May 10, 2010 | 10:19 AM
04FXDL's Avatar
04FXDL
Anyone with pictures or a walk-through? It would be appreciated. I'm waiting for the dealer to call and tell me my forwards are in. I'm def. doing the work myself. I was just going to put the little cover piece over the spline for now. What do you do about the hole in the inner primary cover where the lever went through?
Old May 10, 2010 | 10:37 AM
Evil_keeps_me_young's Avatar
Evil_keeps_me_young
thanks for the enlightening...
Old May 10, 2010 | 10:50 AM
jstreet0204
https://www.hdforums.com/forum/1282246-post4.html
It may take a while to cut it by hand, but using a jig saw like I did, it took abotu 5 minutes to get all the way through.
