Check your drive sprocket bolts
Old 07-01-2017, 08:01 PM
turboc's Avatar
turboc
turboc is offline
Default Check your drive sprocket bolts
I was out for a short ride today and started hearing a loud tapping noise coming from the rear of the bike. I stopped a couple times to check things out and did see anything wrong. After the final stop, I went to take off and couldn't go anywhere. I finally found a sheared off bolt on the drive sprocket, and it was out far enough to wedge against the belt guard mount. There were three others loose as well. It took most of the afternoon, but I got everything fixed.
betho61 (07-02-2017)
Old 07-01-2017, 10:36 PM
Nemosengineer's Avatar
Nemosengineer
Nemosengineer is offline
The drive sprocket bolts are torque to yield fasteners and cannot be reused once loosened, as the mechanical properties of the bolt changed at the time of factory installation.
The reliable fix is to replace all the factory hardware with ARP bolts which are reusable, the stock hardware is is not what I call good quality, I would also replace the disc rotor hardware if it has been removed.
: Mike
TinCupChalice (07-02-2017)
Old 07-01-2017, 10:45 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
: Mike
source sir
Old 07-01-2017, 11:00 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
Originally Posted by cvaria
source sir
Factory service manual.
Old 07-01-2017, 11:01 PM
Nemosengineer
source sir
Hi Cvaria,
Excellent question,The dont reuse fastener warning is the factory service manual, and the ARP recommendation is more or less the word on the street from weekend drag racers, Mudd also made this point in a thread a few years ago when he blew up his rear wheel.
: Mike
Old 07-01-2017, 11:02 PM
cvaria's Avatar
cvaria
cvaria is offline
Hi Cvaria,
: Mike
no no. i trust you. where to get them?
Old 07-01-2017, 11:31 PM
Nemosengineer
Factory Harley-Davidson sprocket yield bolt, bolt head markings indicate this is a grade 8 fastener, removed from my rear wheel showing signs of failure at first formed thread.
Commercial grade 8 bolt for comparison, note the first formed thread.
: Mike
Old 07-01-2017, 11:42 PM
Nemosengineer
Arp fasteners can be bought at Jegs: http://www.jegs.com/webapp/wcs/store...rsistYmm=false
or Summit Racing: https://www.summitracing.com/search/...20and%20Screws
Don't forget to order the chamfered washers...
: Mike
Old 07-02-2017, 04:07 AM
brasher's Avatar
brasher
brasher is offline
SSPirate on here recently had his fail at high speed, took whole sprocket/hub and wheel along with it on his FXDLS!
The dealership denied warranty because the wheel was powdercoated!
Old 07-02-2017, 05:46 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,750 Likes on 3,962 Posts
Wow, that could have been.... bad
turboc, listen to Mike. Mike is good, Mike is wise. And a +1 on the ARP bolts...
Quick Reply: Check your drive sprocket bolts
