2007 Low Rider not charging
Received 4,337 Likes
Have you tested the voltage to the battery? You can cheat and do through the pigtail or across the posts while the bike is idling and at 2000 rpm. Idle = 14.1-14.3v, 2K rpm=14.4-14.8v. Then test stator for continuity. Or pop the derby cover off and if it smells burnt then it's the stator. Check ECU connections for water if you just washed it or drove into some rain.
MachineX
Electrical/Lighting/Alarm
09-05-2014 09:25 AM
