2017 FXDB 2" tank lift before/after
Looks good! Mine will be here from DK in a few days as well. Did you have to use a longer crossover line?
DK Custom - ST (08-22-2017)
**** yea man that looks real nice. Definitely inclined to agree with you with the lines. I wanna do the same thing to my lrs and since it's pretty much the same as the street Bob I think I'm gonna go with the two inch lift. Have you noticed a difference in your distance per tank?
I remember one post where the member said he was gonna adjust the float so his fuel gage would be accurate. I'm not worried about that cause it's never accurate anyway (I just use the tripometer) but I'm curious if I'll still be able to get the same mileage per tank.
Looks real good good though good job.
Looks a lot better lowered in the rear doesn't it. The tank lift makes it look awesome. Since your lifting the front of the tank up, you'd get more gas available to the back allowing you to go further before you completely empty the tank. So, the probability you can go further is likely.
