New spark plug wires
08-24-2017, 03:26 PM
Replaced just the spark plug chords and now bike won't start. Put old chords back on and wouldn't start either. What happened? No error codes. Lights everything turn on but won't turn over at all.
08-24-2017, 04:02 PM
Do you have one of these with a good battery:
08-24-2017, 04:21 PM
I don't have a key fob. I hooked battery up to a tender and it goes to full charge in 10 min so battery is good
Quote:
Originally Posted by
WS6 Formula
08-24-2017, 04:25 PM
08-24-2017, 04:35 PM
2016 dyna street bob
WS6 Formula
What year and model?
08-24-2017, 04:58 PM
Battery cables tight on all four connections; battery, starter and frame? Next would be to check run switch, start switch, and stater relay.
08-24-2017, 05:21 PM
For whatever reason I disconnected the battery and connected it back up and it started right up. Beats me. Thanks for the help and suggestions!
WS6 Formula
08-24-2017, 05:31 PM
Most likely just a bad connection that was good enough for the lights but had too much resistance to turn over the starter.
08-24-2017, 07:14 PM
WS6, you tried, good for you. To the OP good luck next time.
08-24-2017, 07:24 PM
Gurth
I'm sorry, what the **** is a spark plug "chord"?
