Headlight upgrades
Headlight upgrades
Ok, ive read all the previous threads but started new thread because too many older threads causing confusion.
Some of the older threads recommend a simple globe replacement like that sold by dkc.
Later recommendations recommend sealed replacement headlight units, from jw speaker to cheap knock offs from China like the common wisamic
Then the adaptive headlight units came out. First by jw speaker until the cheaper copies came out.
Ive gotta change out the oem headlight (5.75 inch size) but a bit confused with all the options.
Is the adaptive type a useful feature or fad?
Replacement sealed unit or globe replacement?
Is spending top dollar on jws worthwhile?
Thanks for reading.
Thanks for reading.
Being noone’s answered you here’s my opinion. I changed the bucket to 7” and tried the Truck Lite, then changed back to the 5.5” and went with the Daymaker, then bought into the Adaptive hype, it worked well BUT was a yellow 3000K color like stock so not bright but brighter than stock if that makes scence. For brightnest I went back to the Daymaker
Received 2,195 Likes
the 8690A is still the best 5.75 light you can buy. i've run most of the lights out there. adaptive is not a "fad" or hype.
the wisamic and sunpie are the same as the overpriced old daymaker. @$35-50 bucks, you can't go wrong. the new signature daymaker is subpar...
search through here: https://www.youtube.com/user/cvaria4...ber&shelf_id=1 i've tested out a a bunch of lights. i don't say anything in videos on purpose... lights speak for themselves. i promise you 3-4 vids will stand out. they will match up with whats below.
off the cuff.. 1-8 are fine. 1-5 are best i've tested. if you are dropping bank, 1-4 are great. no complex rubric lol
- 8790a/8690a
- probeam/ whatever the real model is the jw rebranded for cd
- 8690m/8790m
- trubeam/vision x vortex
- sunpie and various knockoffs
- 2018+ daymaker signature
- LED h4
- old daymaker (all generations)
- 8620 (terrible)
- stock candle light
In short you're an @$$hat running an LED bulb in a halogen housing.
