Racetech springs with rigor intiminators
Had to rebuild the front end, got racetech springs, ricor intiminators, I want to put the caps on once as I'm old as dirt and had my shoulder rebuilt, I'm 210 what size spacer did any of you guys use who are close to my weight, I really appreciate it
Size of spacer (length) will give you your sag. You are going to have to make some measurements to determine that. On my FXDL, I went with 1.5" of total sag (weight of the bike plus rider), or about 30% of travel. Without external preload adjusters it becomes an iterative process, unfortunately, to get the right length of the spacers.
Racetech should have a recommended length (starting point anyway)
https://www.hdforums.com/forum/touri...rk-better.html
Read this....don’t be lazy...read through it all, super informative....and use Amsoil fluid!
if one has the bucks available the ohlins cartridges are well worth the price, all external dampening and spring tension adjustments, install them once, play around with the settings just a bit, you will save a lot of time vs removing the top caps and constantly adjusting your spring tension.
