2012 Switchback
Old May 17, 2018 | 10:48 PM
JimPrice's Avatar
JimPrice
6th Gear
Default 2012 Switchback
have vance hines pipes on my 2012 switchback.
Love the low end torque.
Anyone have any suggestions on what I can add for even more hourse power¿
thank you in advance,
jim
Old May 18, 2018 | 08:11 AM
1HD1C's Avatar
1HD1C
open AC , decat the head pipe and a V&H FP3
Old May 18, 2018 | 08:51 AM
natedog_37's Avatar
natedog_37
Skip the V&H FP3 and get a Power Vision. Get a stage one intake, and go from there.
Old May 18, 2018 | 12:44 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Jim, what power level is your goal?
Old May 18, 2018 | 06:42 PM
crusader1xxx's Avatar
crusader1xxx
What Norty said...you have to be smart about what you want in the end...just throwing parts on it and hoping it works is an expensive gamble...
if if you have a pipe, next logical step is a high flow air cleaner...DK Customs has some excellent ones...then a full tune of your ECM...you should have it tuned to run properly
Old May 19, 2018 | 10:45 AM
JimPrice's Avatar
JimPrice
6th Gear
I enjoy JUMPING off the line, out of the hole. Like to get every hp out of the 103ci. Thinking air is my next step, want to change it once. In your opinion which one should I install?
Old May 19, 2018 | 03:48 PM
nevil's Avatar
nevil
If you're going to install an intake, do it at the same time you get a tuner. Without a good tune, you'll be running very lean with just pipes and intake. The tuner will let you get the most power out of your setup, and not have the bike run too hot. As for an intake, I got rid of my Big Sucker and went with one from DK Customs that will vent to atmosphere.
Old May 19, 2018 | 04:23 PM
Pylot7's Avatar
Pylot7
Here is what I did.
I discovered that you have to choose where you want to be, assemble and install that combination then get the bike tuned for it.'
I went from stock to a fuel moto e series 2 into 1 exhaust, a set of woods cams designed for low end torque and a K&N filter to let it inhale.
My torque should come on at about 100 ft pounds at about 2800 rpms and sit flat to about 4800 or so which is where I shift it.
Keeps the torque up and the rpms down.
You can make smaller incremental steps. But ultimately the cams in conjunction with a well considered intake and a complementary exhaust will get you the torque you seek.
Let us know what you do.
rchop
Mar 16, 2015 02:31 PM
SS-HD
Nov 19, 2013 05:33 PM
2bo88
Exhaust System Topics
Sep 30, 2013 11:27 AM
JFonzka
Oct 7, 2007 08:08 PM
pauletich
Jun 1, 2006 01:56 PM
