Vibration Mostly Cured
Old Jun 3, 2018 | 10:50 PM
Huggerbugger's Avatar
Huggerbugger
Default Vibration Mostly Cured
My Indy took my TPS off, cleaned it out and opened the hole up a little. Now runs much smoother. 39 bones for labor. Happy.
Old Jun 4, 2018 | 12:42 AM
cggorman's Avatar
cggorman
TPS hole?
Regardless, that's excellent news.
Old Jun 4, 2018 | 09:17 AM
F86's Avatar
F86
Originally Posted by cggorman
TPS hole?
Throttle Position Sensor?
...or TPS reports?
Old Jun 4, 2018 | 09:59 AM
cggorman's Avatar
cggorman
Yeah, throttle position sensor. I'm just confused a bit by the mention of enlarging a hole. The TPS is a potentiometer...no holes...unless it's the throttle horn hole for the throttle cable, but that doesn't make sense. Maybe the IAC (Idle Air Control) valve. That has a passage on either side of the throttle blade, but I've never heard of anybody needing to enlarge them.
Old Jun 4, 2018 | 10:01 AM
crusader1xxx's Avatar
crusader1xxx
Old Jun 4, 2018 | 10:27 AM
multihdrdr's Avatar
multihdrdr
... doesn't make sense...
c'mon 2+2 =
...too cryptic?
Old Jun 4, 2018 | 10:29 AM
Huggerbugger
Don't know what he meant, but it sure runs like it used to.
Old Jun 4, 2018 | 10:34 AM
iaminsider's Avatar
iaminsider
What were your symptoms before the fix?
Old Jun 4, 2018 | 10:41 AM
Huggerbugger
Extraordinary vibration.
Old Jun 4, 2018 | 10:51 AM
iaminsider's Avatar
iaminsider
Can you be more specific? Certain RPMs? Which RPMs? Idle? Only idle? Acceleration? Deceleration?
The more info the better for this thread.
