click from front end when braking
On a trip i just finished i noticed that I developed a click in the neck under heavy front braking. It doesnt feel like it is flexing but im pretty sure it is the bearings or at a minimum the tension. is 2014 fxdl and it has 30,000 miles. it is in need of basic serice right now anyway. The book says to lubricate the neck bearings at 30,000 miles. Do you actually have to take the front end off and remove the bearings to pack them in grease? do yall do that every 30,000? Then I guess do the fall away procedure?
Or should i just do the fall away procedure and see if it stops clicking?
The steering feels good to me and the side to side is smooth
I had a similar thing happen on my 06 fxd and it seems like the dealership fixed it with a differnet type of washer maybe, it was a while ago. Anybody know if there are any service bulletins on this for 2014 dyna
any advise would be greatly appreciated.Like i said it feels ggod and rides good and it doesnt feel sloppy to me, but it does click when using the front brake heavy or over big bumbs
pleas advise
pleas advise
Were the forks ever rebuilt with a full fork seal kit? Im asking because there was a chopper with a wideglide in a buddys shop that was clicking because the bushings where worn from the front end being really long.
i would check the fall away and go mabye a quarter turn tighter then check again. If its still happening then i would rebuild the forks completly. Doesnt sound like the brakes to me.
Were the triple trees ever removed? All the correct washers are in there right?
if you have a lift lift it up just enought to be off the ground and shake the front end a bit. Tie the bike down too so it doesnt fall off. Then go a quarter turn on the nut attached to the steering stem. You will need to find the sweet spot.
