Tires or Brakes?
Tires or Brakes?
New to the Forum, but I have had my 2012 Switchback for about 900 miles so far and I'm noticing a vibration/noise when braking/slowing down leaning into a corner? I do not notice the vibration at speeds or cruising? The bike has almost 11,000 miles. The tires look good, but I have read they could be the problem and now I'm concerned about the brake pads. The front brakes will make a slight noise when applied. This is my first Harley so not to sure if this is normal, but I assume not. Thanks in advance!
When slowing down with the front brake while entering a corner when I lean I hear a grinding like sound and you can feel it through the handlebars? I have checked and everything is tight and I have plenty of brake pads left? Cannot add picture?
Received 4,616 Likes
That grinding in a corner can be a wheel bearing. Look at the seals, see if one is partially dislodged, or grease or rust streaks coming out from the bearing. If you can lift the front wheel (pretty much means you have to have a jack), hand spin the wheel to see if there's brake drag or any roughness that could be a bearing. Vibration can come from neck bearings, too, but I doubt they'd make your grinding noise. Used to be the most common cause was the front tire, but now a lot of guys with later year Harleys are reporting bad wheel bearings, its worth checking out. Tire is annoying, wheel bearing can put you down. Unfortunately sometimes there's nothing to see for a bad tire, and sometimes you can't feel a bad bearing by spinning a wheel, have to take the wheel off, pop a seal and look inside, turn the inside race with a finger while the axle's out. That's worst case, often they let themselves be known, tires and bearings both, if you know what to look for.
Check tires for cupping check tire pressure get the front wheel off the ground and inspect wheel bearing. Replace pads and check rotor thickness. Also fallaway procedure should be checked at 10k. Also inspect the front motor mount as well they get damaged during oil changes by the old oil falling onto it when removing the oil filter
Huggerbugger (10-07-2018)
