Flywheel Runout over .020.
If the pin fit is correct, and the material is inferior (not meaning bad quality but lower strength), the best weld in the world will not improve the strength as compared to a proper fit, higher strength pin/flywheel. One benefit of higher strength materials is that they support more interference (between the pin and the flywheel) which sustains more torque before slipping. Furthermore, with tighter tolerance control, higher nominal interference can be used without fear of exceeding the yield strength. This further would increase the torque that the pin could take before slipping.
OK, so why would that make a difference unless there is something seriously wrong with the case. I guess that the machine shop can pull the crank & put it in some calibrated v-blocks but how many shops do that?
Kingglide549 (12-07-2018)
TIR is Total Indicator Reading..... from min to max. Actual runout is the distance from the nominal to the min or max.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
The following 2 users liked this post by ROCKOUT Rocker Products:
crusader1xxx (12-07-2018),
Huggerbugger (12-07-2018)
If the pin fit is improper, then sure, welding will help. Maybe lot of stock Harley pins have a loose fit.
I can and most welders could weld that so something else will fail, not the weld.
Yes the original steel is probably crap- if the interference is correct the failure should be with the original material.
Not the press.
That said, an interference fit is only as good as the parts and , machining involved.
I was told the HD wheels (crank) are now made offshore, which would explain a lot.
Runout basically is at any point along the feature, independent of any other point. TIR is at ALL points along the feature, inclusive. If you picture a crank that has shifted, AND the output section is bent.... runout will be less than TIR as the latter is from the lowest low to the highest high along the entire distance.
How many HD flywheels have you had welded? I've only done one and welds cracked. A GS1000 is not the same as a HD. Yes I've seen Jap bikes welded but they don't run the level of interface fit plus use better steel, Loads are much higher compared to the GS when you factor in surface area of the pin.
https://www.youtube.com/watch?v=hkLUWqnk9s4&t=92s
TIR total indicated run out. So if the needle swings .020" the actual run out is .010"
Also I certainly know the difference between a multi piece ball bearing crank and a Harley single pin crank....Just put the GS1000 experience in the post as a caveat as to the pain I went thru.
As I said before if the crank is in good overall condition I would pin and weld this is not the same as just a surface weld.
That much would surely put a bind on the crank bearings if it was scissored.
Keep in mind, a straight true shaft in a close tolerance bearing like a ball bearing when turned will always be true. A TC crank is pressed together. The sprockets drive is very tolerant of runout. .012 hurts nothing out on the end and that is the manual spec..020 would be OK if it was just the cam sprocket shaft
Well that means that you need to V out location of the weld and fill. Unfortunately no one does it. The pin is hardened and would be hard on tooling (even carbide). It you did you'd still likely have issues as when welding, the press fit relaxes. The best way to tighten the fit is with a steel plug on the ID of the pin and use the best materials you can get for the wheels. Or use a forged one piece crank.
