FXR - which trans do you recommend?
I think it'll be interesting. I plan on pillaging the front end and rear suspension from my FXDX, using touring brembos and floating rotors, and possibly the 13 spoke mags.
I plan on following your lead for weight loss and using some aftermarket, plastic and aluminum parts (fenders, tank?, gauge, bars) wherever feasible.
I want to rewire minimally and effectively, using leds and an m-unit if I can afford it.
You want to change the way the bike feels on the highway you need to play with primary ratios and final drive sprocket gearing to drop the motor RPM, only way to it without spending big change on an actual aftermarket 6 speed overdrive trans like Bakers.
Is not going to be as simple as you are hoping it will be sorry.
Very little that I do is.
I'm not programmed to do things the easy way.
Having said that, thanks for the info.
My goal wasn't searching for overdrive, if anything, it'd be the opposite: more takeoff at a light.
But I'll use sprocket/pulley gearing, weight loss and engine mods for that.
Maybe I should've re-worded my question to: With $500, which transmission would you buy?
My apologies for not clarifying.
I don't mind going with the stock trans, but I was trying to get a 5 speed:
- to avoid design flaws (i.e. woodruff key),
- I'm used to a 5 speed and fear the "big gaps" of the 4 speed
- I thought they might be most plentiful and therefore least expensive.
- since I don't have the stock one anyways, why not see what FXR riders recommend
(Thanks FXDLX)
I didn't want a 6 speed because highway revs with a 5 didn't bother me with my Dyna and I already spend enough time wondering which friggin gear I'm in.
Maybe putting a splined shaft 5 speed trans in a 1985 FXRS,
or putting a splined shaft 5 speed gearset in a 1985 trans box is not worth the trouble.
But that's why I'm here.
(Thanks FXDLX)
sporty79 (01-13-2019)
Originally Posted by theduroche
Okay, I'll reach out to him. Thanks.
Okay, but wouldn't it be a d1ck move to ask him for info and not buy one of his products?
I'm starting to revisit my previously abandoned idea of using my entire 2001 FXDX drivetrain.
