How to Touch Up Wrinkle Black
03-09-2019, 09:08 AM
Last fall I laid down my 2008 Street Bob. The outer primary is ground up/scratched area is below the derby cover. It is a fairly big area but since it is on the bottom, you really have to lay on the ground to see it. I want to touch up/repaint it w/o removing the outer primary. Looking for advice on how to do this!
03-09-2019, 10:00 AM
U could just use some matte black heat resistant paint from your local hardware store that u can gently brush on. Itll cover up and blend with the rest of the case. Doubt anyone will notice. $15 job for paint and a brush .
03-09-2019, 10:36 AM
VHT wrinkle black spray paint
03-09-2019, 09:12 PM
Quote:
Originally Posted by
Kraken
That sounds like a really good suggestion. Otherwise, use a sponge to add texture to the paint of your choice.
03-10-2019, 02:46 PM
John CC
VHT wrinkle paint needs to be baked to see any appreciable wrinkle.
03-10-2019, 10:11 PM
Blue Bob
I did the intake for my truck in it and it wrinkled very nicely without baking. It does need to get hot to fully cure though.
03-10-2019, 11:14 PM
toddskill
As per VHT's website:
Curing Wrinkle Plus™ VHT Wrinkle Plus only attains its unique properties after correct curing. Bake at 200°F (93°C) for 20 minutes.
The inherent heat of engine operation will also accomplish curing.
03-11-2019, 12:18 AM
Blue Bob
I know what the label says, I also know that it works without baking. It is very soft until it gets baked, but the wrinkle still works just fine.
03-11-2019, 08:08 AM
toddskill
Not label...website. Sorry to confuse people. You are right....no reason to follow directions
03-11-2019, 08:24 AM
Well, OP doesn't want to remove the cover, so I guess you could bake the whole bike...
Or, use the sponge!
