Lite clutch kit?? 40% easier clutch??
#31
Powered Clutch System for motorcycles
Adaptive Technology, LLC has redesigned their EZ-F Powered Clutch System to a much smaller version. The picture on the website is the original version and the new one is about 1/3 the size. This system uses 12V power to pull the clutch cable with no compromise of throw distance. Easy to install and requires no mechanics or modifications to the engine. Worst case, you will have to remove the fuel tank to run the power wire from the battery.
The force at the clutch handle is reduced from about 20lbs down to about 1-2lbs. Originally designed for folks with left hand disabilities, and other hand pain, it is perfect for anyone. I am not sure when the website will be updated with the new pictures. But give them a call...... www.AdaptiveTechnologyLLC.com
I have one of the originals on my Honda Saber and Fatboy and love it.
Max Headflow (06-07-2019)
#33
I put the Burly in this winter as the heavy duty clutch spring was tiring on the hand during parades and long group rides. 40% less is about right but to make sure it seats fully I will say there is more friction when I have it pulled all the way in than there was before. Not enough to move the bike, but it wants to go. I felt better putting it in with an AIM VP clutch plate though to help create more pressure with higher revs.
#34
I honestly cant imagine the clutch being any easier to pull than stock (mine is 2014) and it has almost zero resistance
seams like my 06 felt the same way
maybe if you have a hand injury or something like that, bad arthritis maybe but to me its like saying the throttle is too hard to turn
#35
#36
yea ok I get that, performance clutch with stiffer springs now that makes since but the stock clutch is pretty light, I almost think the stock clutch is too light for my stock 103
now my '80 ironhead, that clutch will give you a cramp if you get stuck in traffic but on the good note when you dump the clutch you can feel that thing snap shut!
csharley
01-31-2013 12:23 PM
