2000 dyna. Runs great for 5 mins then dies.
Have a 2000 dyna. I’m slowest going through the entire bike to essentially restore it. I have an issue. I rebuilt the carb and it runs and idles better than it ever has. Take it for a test ride and about 3 miles in, the engine will die without warning. Let it sit for 5 mins and it’s fine. Then dies again. Double checked everything in the carb and it looks correct. Is it related or ignition?
Also so one thing I changed was removed the Evaporative Emission Control System- aka the charcoal canister. One of the lines from this canister was running to the carburetor. I removed it and plugged the hole in the carb. Could this be the issue? Anything else I missed when removing this canister that I was supposed to do!? I’m perplexed.
Are you sure that the float is set correctly in the carb? It kinda sounds like you may be running out of fuel in the bowl. Probably not the issue, but you could also try flipping to reserve as it's starting to die... Maybe there's debris in the tank getting clogged up on the petcock screen. The reserve position may still allow enough fuel flow. My 2000 has a vent line coming out of the front of the tank tunnel... Is that line present and clear? Do you have the original vacuum petcock? If so, is it getting vacuum properly?
crusader1xxx (04-29-2019)
Received 4,309 Likes
Try running with your gas cap loose to verify problem.
