This question I'm sure has been discussed here before but here's my issue. Installed woods 555 cans in my 2010 street bob along with woods lifters and fuel moto pushrods.
Since the installation the bike fires up fine and sounds good but has no power off the line. It feels like I'm taking off in second gear but seems to run strong at higher rpm.
My other issue is fuel, just did an approximate 70 mile round trip and went through an entire tank of gas.
I thought I had the timing Mark's lined up, but maybe I was off? Any help would be appreciated. I'm using a v&h fp3 tuner also
PD Restoration can help....in the mean time check your dots..then do a compression test...anything funny with the numbers should lead you to finding the problem...if it ran good before, and all you did was change cams and I am assuming you have retuned it for the new cams, then something out....
After the cam install I tuned it for the vance and hines pro pipe, standard baffle and high flow a/c. I then added the woods 555 cam. I noticed it not having much power on the low end so I tried to auto tune and couldn't get any cells green. I haven't gone deep into adjusting the air fuel ratio or anything else as that's a bit above my knowledge. Seems like I could do more harm than good.
they say the 555's are not as good of a low end as the 222's which I have in my bike. the 222's give me good low end and better top end than the stock ones.
You then added the woods 555 cams? Did you flash a new map that included the woods 555 cams?
The 555;s look like great cams...don't be worried about it being a cam problem...It's most likely a tune issue IF the cams are installed correctly.
There is a measurement known as "dynamic" or "corrected" compression. Basically, an engine cannot begin building compression in a cylinder until all of the valves in that cylinder have closed. The Woods 555 closes the intake valve at 41 degrees after top dead center, the factory 2010 Fat Bob cams closed at 30 after TDC (11 degrees sooner). This means that you will experience a loss of compression by installing that camshaft vs the factory camshaft, which is why some camshafts recommend high compression pistons or headwork to achieve high compression.
Here is what Mikuni has to say about the subject,
Cam Basics:
Correct cam selection is the single most difficult choice facing the performance enthusiast. And, unfortunately, we get it wrong about as often as we get it right. An incorrect cam choice can result in decreased real-world performance if the selected cam's operating range is not matched to riding style.
The operating range of any Harley engine is determined by a number of factors and the cam design is one of the most influential. If the cam design is not matched to the other components and is not matched to the desired engine power band (rpm range), then the engine's performance will be disappointing. No amount of carburetor tuning can compensate for having the wrong cam.
To get the "right" cam design, you need to do two things: First, decide upon the rpm range you want to improve. Secondly, use the list provided below and cam catalogues to select a cam design that begins to work at the lower rpm of the power range you have chosen. You'll probably be surprised to learn how few of the available cam designs fit your expectations. However, the list is accurate and if you follow its implied advice, you will get an engine that performs as you wish it to.
Cam timing: what matters
The most important cam timing event is the intake valve closing angle. The intake closing point determines the minimum rpm at which the engine begins to do its best work. The later the intake valves close, the higher the rpm must be before the engine gets "on the cam."
Long duration, late closing cam designs are necessary to drag the last bit of power out of an engine. Unfortunately, these same cams can perform poorly under more normal riding conditions. In the quest for maximum power output, many-too-many Harley owners choose a late closing, high-rpm cam for their engine. The problem with such choices is that the engine seldom spends time in the rpm range favored by such cams.
The majority of virtually any Harley motor's life is spent in the mid-portion of its rpm limits, between 2000 and 4000 rpm. At open-road cruising speeds, that range is more like 2500 to 3500 rpm. With current Big Twin gearing, top gear at 2500 rpm returns a road speed of 55 mph and 3500 delivers 84 mph. Riders sometimes "putt" around at 2000 or less. Even when accelerating to cruising speed, few of us use more than 4000 - 4500 rpm as a shift point. Very seldom, in day-to-day use, do our engines get near 5000 rpm, let alone 6000.
Even the mildest of Harley-Davidson's aftermarket cams (Evo or Twin Cam) do their best work above 3000 rpm. At 2000, the majority of these cams seldom perform significantly better than stock cam(s).
The rpm at which a Big Twin gets "happy" can be predicted by the closing point (angle) of the intake valves. The angle is expressed as the number of degrees After Bottom Dead Center (ABDC) that the valves reach .053" from being fully seated.
The following list predicts the rpm at which the engine gets "on the cam" based on the closing angle of the intake valves. These relationships are approximate but should hold true to within 200 rpm or so. They also assume that all other tuning factors, exhaust, ignition, etc., are operating correctly.
30 degrees = 2400 rpm
35 degrees = 3000 rpm
40 degrees = 3600 rpm
45 degrees = 4000 rpm
50+ degrees = 4500 rpm
If you have one of the late closing cam designs installed, say one that closes the intake valves later than 40 degrees, then you cannot expect excellent performance at 2000 rpm. No carburetor adjustment, ignition adjustment or exhaust system can change this.
