Want better performance on 07 dyna super glide
When you do the big bore it really only helps if you also increase compression. If you increase compression the 48 becomes inadequate and the cams have to be replaced again to see much gain. If you plan to do the big bore in the future and just don't have the money for it yet I'd suggest the 57 cam unless you want to eat the around $200 for swapping the cam and selling the used one.
Even with the 70K miles, the 2007 with the 48's and pro dyno tune stomps the hell out of the stage 1 2012. Flat out runs away from it. Night and day difference. I originally thought I'd go to big bore, but no need for it as far as I'm concerned.
I just used the 030 head gaskets to bump the compression slightly and improve the squish characteristics. Another bonus of that is Andrew's 48's with 030 head gaskets allows you to run the stock pushrods. That was according to Andrews tech support. Some people don't mind adjustable push rods, but I prefer solid one piece push rods.
I can't stress the importance of a pro dyno tune enough. I had started with the recommended TTS map and then auto tuned it myself. I thought it was running pretty well and felt a little foolish spending the money for a pro tune. Wow, was I wrong. There was a huge difference in performance after the pro dyno tuned it. Huge difference. I've put 45,000 miles on it since the tune, and it still runs great.
Good luck with whatever you do.
Received 2,189 Likes
Received 5,388 Likes
DynaDownLow
Dyna Parts
10-13-2017 08:13 AM
