Which 14 inch apes?
Old May 4, 2020 | 11:12 AM
wandrur's Avatar
wandrur
The wrist angle is very good for me, too. The only thing that is a little odd to me is on full turn with a low master cylinder, you might suck air into the line if you apply the brake (which would be a bad idea anyway...). But that can also be partially remedied by rolling the bars forward or backward a bit.
In hindsight, I should have gone with the 12" rather than 14", but that's just how it goes.
Old May 4, 2020 | 11:35 AM
REW13's Avatar
REW13
Here is the honest question...
How tall are you?
I'm 6'5 and started with 12's first, then went to 14's, then put a 3 in riser on, now looking at 16 to 18. I feel like I need 2 to 3 more inches for my total comfort....
So before you buy try to find your zone....
What size bars are on the bike now? Either use a prop or have someone hold a ruler up to get an idea..
Another thing... If you have a narrow front end, make sure you order narrow bars.... To me it doesn't look right when you bar bend is way outside of triple trees
Old May 5, 2020 | 11:47 AM
snake_eyes's Avatar
snake_eyes
FMB Choppers https://www.fmbchopperparts.com/ practically 0 angle, almost like a T bar and narrow at the base as you can see. Mine are 16" but they can make them any way you want.
Old May 6, 2020 | 10:10 AM
REW13's Avatar
REW13
Dig'em Snake.
Old May 6, 2020 | 11:20 AM
MikeK13's Avatar
MikeK13
Originally Posted by Carl '69
Burly narrow 14"s on my '02 FXD before I FL'd 'er.
Dude thats perfect right there
Old May 6, 2020 | 03:03 PM
REW13's Avatar
REW13
And depending on the wires. You might also be able to get away with a taller riser too. I know that a four inch will work, but again depending on your cables.
Old May 6, 2020 | 09:45 PM
Carl '69's Avatar
Carl '69
At 14", forget using stock throttle or clutch cables or brake line. I used NAMMZ wiring harness extensions, but forget what length clutch, throttle & brake lines I went with. Clutch cable's a little longer than necessary, but no biggie. I know it's more time consuming, but wait till you get your new bars & get good measurements for cables, etc. There is a whole bunch of excess/slack wire stuffed into the frame, so you won't need near as long of wiring harness extensions as you'd think.
Old May 6, 2020 | 10:07 PM
Tall Timber's Avatar
Tall Timber
+1 for 14" wild1 chubbys outlawz
Old May 8, 2020 | 10:55 AM
REW13's Avatar
REW13
Just ordered 16's Burley narrow... Plus wires. Yay taller
Old May 8, 2020 | 11:02 AM
Harleylife1's Avatar
Harleylife1
Id say take a look at wild 1 chubbys. That's always who I recommend for handlebars. Safe travels.
