I pressure wash it like 3 weeks ago....and it has been acting strange after.....also oil has been changed, but I dont think that has anything to to with it....
it is 2014 SB with power commander 5....
I openeed all PC5 and ecu plugs and checked if there is any water, I left them open throughthe night and used hair dryer too.....still stutters
it stutters when you use only little throttle to keep it at constant speed....so it cucks....bit time
I tightened battery terminals too....i dunno what to do next.....
You might want to rethink using a pressure washer. Not only bad for electronics it also forces water into bearings, wheel and neck. Also spoke nipples which rust quickly.
You can try autotune if you want, in case the map was corrupted somehow. Removing it will eliminate the unit itself as possibly being defective.
Check for intake leaks between the intake manifold where it attaches to the head of each cylinder.
i see, so there might be leaks....i dont have the starter spray.....tomorrow I am trying without power commander 5 first but if the problem still persists I will have to take it to service.....
so to replace intake gaskets you need to remove the tank?
I thoguht the suggestion was to spray around intake gaskets to see if the motor changes sound so you see if there is a leak in gaskets of the manifold like the guy showed in video
mass throttle spray is for cleaning....not for detecting leaks right? so why you suggest it?
