TW222 07 WideGlide update, stupid me!
Well, I am a dumbass🤣🤣. When I installed the pushrod clip on cylinder #1 intake the bottom section that goes into the lifter box moved and the O ring was pinched causing the pushrod to make contact with the tube. Only noticed it when I saw a ton of smoke from the oil burning on the exhaust pipe🤪🤪🤪. Popped the clip, collapsed pushrod, replaced O ring, reassembled and HOLY ****! The bike is completely transformed and rips like it should, is super smooth and pulls pulls pulls!! I usually never take her past 5 grand but it just begs for the throttle to be twisted to the stop and bounced it off redline.The FuelMoto flash is just awesome, not one hiccup from idle to redline thanks FM!!!!
if you are on the fence with this cam ,just do it !!
DanHappy (06-03-2021)
crzoomb (05-31-2021)
I knew I didn't like the angle of the rubber-band holding the PR tube in the second photo of your install thread. I saw that jinx coming from a mile away, couldn't nothing be done about it at that point, the jinx was in!
Rubberband either on the middle rocker cover bolt head or in line with the PR tube but never in juxtaposition to cataclysm. It's a jinx I tell ya
Good job though
Good job though
tully_mars
Engine Mechanical Topics
12-25-2023 07:39 AM
