Handlebar wiring harness
I have a 2003 wide glide and I just mounted the new handlebars. I bought a complete line, cable, and wiring kit from Magnum Shielding, so I have pretty much everything ready to go. My problem is I can’t locate the handlebar wiring harness. There was a grommet on the very front of the frame on the left side that I took out and tried pulling any available slack, if any. There wasn’t hardly any budging. I have the seat off already and tried pushing any slack up the frame. Everything seems pretty taunt already but hear that the harness may be inside the backbone. How the hell can it be accessed is beyond me. I mean, I could cut the wires and solder enough on but I’d rather extend the existing harness, wherever it is. Trying to get this done either tonight or tomorrow. Any help is greatly appreciated. Thanks a bunch.
Glad you got it figured out, I didn't want to say anything cause I didn't know how different yours is from my '14 SB. If it is similiar there's a lot of excess wire in there and it all has to go back in so you might want to clean the looms of dirt and grime if any and apply something that makes them a little slippery when you stuff it back in. I knew a guy who put tons of some type of lube and he used a ton, some use dish soap, I just put some Armor-All on them.
Good luck
Good luck
Uncleporkchop (02-13-2022)
Good luck
Good luck
