2007 FXD Oil leak out of clutch cable
Just noticed my new/used 2007 FXD is weeping oil out of the clutch cable. Not the fitting, the fiber webbing is almost greasy and oil is present. Oil level appears correct. Checked vent tube. It's clear. Removed fitting. it's clear. However, when I attach a hose to the fitting and blow in it, there is resistence. With the size of the breather tube, and the size of the trans chamber, I would expect free flowing air, without resistance. Also, is there a seal that stops the trans oil from traveling into the cable?
Thanks!
Thanks!
SoflaSteve (09-01-2022)
The following 2 users liked this post by FXD2003Rider:
eighteight (09-01-2022),
s-glide76 (09-04-2022)
Hundred Dollars
02-14-2012 09:01 AM
