Rear brake caliper rebuild strange discovery
Hello everyone,
I'm restarting working on the bike to get ready for the spring. So almost there, only brakes checking and disambly missing before painting the caliper...
After disassembling the rear caliper fond this strange black marks inside, As I have never done this on a DYNA, is this looks fine to you or have you ever seen something similar?
Thank you for your help
p.s. the bike is 3000 miles only
both
left
right
both
left
right
The following 3 users liked this post by John CC:
Wish I can take better pictures...
p.s. the pistons are immaculate, was going to change them but they are perfect, not even a mark...
There is no chrome in the bores. You're seeing the difference between the raw casting and the machined, finished surface.
If you look down into the fluid passage at the bottom of the bore you will find the same sort of surface.
If that was on my bike, I'd run it without concern. But I'd also be a little miffed about it.
I haven't done thousands of calipers, but I've seen exactly the same thing many times.
eighteight (03-08-2023)
Bingo!! we have a winner, all that kind of stuff is post machined after the coatings are applied. There's always small variation in the rough castings, see it all the time on the job.
