07 street bob running off one cylinder
  #41
Old 01-02-2024, 07:33 PM
John CC's Avatar
John CC
John CC is online now
If the plug is not firing but fuel is being injected it will be wet for several minutes at least. When the problem occurs, pull over (safely) and pull the rear plug out.
With a carb the good cylinder could be wet. Not likely with EFI.
The two primary windings are measured between A and C and between A and D. HT means High Tension. Measure from A to each of the HT terminals for the secondaries. If the primaries are good it wouldn't much matter if you used A, C or D. You could also measure the two primary windings simultaneously by measuring between C and D. Expect twice the reading, or 1.0 to 1.4 Ohms.
hattitude (01-02-2024)
stewart1962
The Dyno Room
03-30-2017 12:32 AM
blowder
10-10-2016 10:29 AM
vivbarry
07-21-2014 01:13 PM
wiscdyna
04-17-2013 05:53 AM
boutellepc
08-09-2008 06:35 PM
Quick Reply: 07 street bob running off one cylinder
