Windghost
Old Oct 6, 2016 | 02:45 PM
blowder's Avatar
blowder
1st Gear
Default Windghost
I ride an 07 street bob i am running V&H short shorts stage1 performance aircleaner and programer however it's hard to start when it gets up to good running temperature. For the most part it starts pretty good when it is cold or cooled down. Could i be suffering from a bad compensator? Any comments?
Old Oct 6, 2016 | 03:27 PM
TinCupChalice's Avatar
TinCupChalice
That compensator isn't your issue; what programmer are we talking about? This is a tuning problem...
Old Oct 6, 2016 | 04:15 PM
djorgensen3's Avatar
djorgensen3
Describe the hard start issue a little more clearly. Does it seem like the engine is hard to turn over or does it spin over easily and act like no fuel?
Old Oct 6, 2016 | 04:35 PM
blowder's Avatar
blowder
1st Gear
it wants to kick back and sometimes even coughs through the aircleaner
Old Oct 6, 2016 | 05:05 PM
blowder's Avatar
blowder
1st Gear
i used the power commander programmer. The pipes air cleaner and programmer was installed in shop. i also want to add that the bike has 90k miles on it i have not let the grass grow under it. this issue has really shown its face since i changed the baffles in the pipes. the originals started rusting apart.
Old Oct 6, 2016 | 05:55 PM
djorgensen3
Don't make it harder than it has to be. I doubt it's a tune issue. It sounds just like the multitude of inadequate CCA battery threads we have seen lately. Try a bigger CCA battery just for grins.
Old Oct 6, 2016 | 08:27 PM
blowder's Avatar
blowder
1st Gear
Sounds like a quick and easy fix thanks I give that a try. Any other options out there?
Old Oct 6, 2016 | 08:57 PM
Warp Factor's Avatar
Warp Factor
Yup, 9 out of 10 times the issue can be solved with a fresh battery, even when the old battery "tests" as being good.
Old Oct 6, 2016 | 09:28 PM
Ghost_13's Avatar
Ghost_13
My top three suspects (no particular order) compression release sticking..., weak battery..., starter going bad
Systematically troubleshoot and identify
Ghost
Old Oct 6, 2016 | 10:18 PM
cggorman's Avatar
cggorman
Just for giggles, remove the mufflers and go for a ride. Try to hot start without them installed. May be a coincidence, but doing this will help rule them out.
