Going To A Solid Mount Engine???
Old Feb 25, 2024 | 03:17 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Graham UK
The only time I had a wobble on my Low Rider was when the head bearing needed replacing. The rubber mounts last well and the handling of the Dyna is awesome. So, personally, I don't see any advantage in removing the mounts. But, if you do, keep us posted, because if it turns out to be a great mod then others will follow!
Do you ever get up to and past 110 mph? I also get death wobble then but can power through it up to 125 and kinda lay down on the tank.. Tucking in behind the bars does eliminate death wobble..
Old Feb 25, 2024 | 11:37 PM
user 7209823083's Avatar
user 7209823083
Originally Posted by 08xl1200r
Yep, agree, and FWIW that is the case in the Norton Commando world...the rubber "Isolastic" mounts are adjustable and if you get them too tight frame cracks often follow.
In all fairness it should be noted that when it comes to vintage British motorcycles, if you do any action beyond leaving it stashed in your garage, cracks often follow..
Old Feb 26, 2024 | 06:38 AM
Architect's Avatar
Architect
Bill Dodge from Bling's Cycle has been building rigid frame bikes with modern HD drive trains. I am pretty sure he takes Twin Cams for Touring bikes and mounts them rigidly, into a rigid frame.
Look him up, maybe some of your answers are there, good luck.
Old Feb 26, 2024 | 07:00 AM
98hotrodfatboy
Excellent... Thank you Bill...
Old Feb 26, 2024 | 07:14 AM
eighteight's Avatar
eighteight
Do you ever get up to and past 110 mph? .
Only when racing C7 Corvettes
Old Feb 26, 2024 | 07:15 AM
user 7209823083
There are quite a few rigid choppers with Twin Cam engines on the roads here in Sweden. Most of them are using Softail engines with balancers since they are designed to be rigid mounted, but there are a few with Dyna engines as well. As far as I know the engine vibrations are not an issue even with the TC A engines, the thing that keeps most builders from using Dyna engines is that the oil tank hangs quite low under the transmission making it vulnerable to damage running a low bike.
I would think that vibrations are not an issue with rigid mounts in a Dyna frame, but I agree the forces acting on the swing arm mount could be a problem.
Old Feb 26, 2024 | 09:53 AM
snake_eyes's Avatar
snake_eyes
Valid point and that's why I ask..
Invalid point, read what I asked... Please, your labeled as nothing but an instigator So please STFU...
Block him, I did. Makes my life so much easier.
KentuckyChristian
Feb 28, 2024 12:02 PM
hardheaded
May 19, 2021 10:29 AM
ditchbanger
Jul 12, 2015 08:57 PM
Zinje
Sep 3, 2012 10:26 PM
fortune
Apr 29, 2010 03:54 PM
