Gas leak 2007 WG...help
09-15-2007, 05:01 PM
When I fill-up tank, gas can be seen running out from under the leather center strap near the instrument clusterand onto top of gas tank.
What is the problem?
09-15-2007, 06:55 PM
RE: Gas leak 2007 WG...help
Did you have any work done on the fuel pump or sender?
There are seals on the screws that can only be used once. If you try to reuse them the tank will leak.
Good luck!
09-15-2007, 07:35 PM
Take strap off and see where the leak is coming from.
09-15-2007, 07:43 PM
Yup, gotta start looking......if you didnt do anywork to the console or tank, could something have hit it?
JF817
09-20-2017 11:48 AM
huskers11
05-17-2012 10:55 PM
fogcity123
EVO
08-15-2011 05:15 AM
PJW
Carburetor Related
01-04-2010 02:11 PM
the4thgearkid
05-06-2009 05:47 PM
