19 inch wheel on a FXDWG 06
RE: 19 inch wheel on a FXDWG 06
The wheel will fit but the caliper will not line up with the rotor. The hub on the Dyna which come with a 19" are narrower than the hub on the WG. You can get new wheel spacers to eat up the extra room on the axle. The caliper can't easily be moved though. I don't know if they make a spacer to move the caliper out further or not.
It may be easier to buy a 19" rim and spokes and lacethem to your WG hub. Again, I don't know how available these parts are.
The look will be dependent on an opinion. Lots on here have 19"s but want the 21". The ride should be fine.
greenyone
10-19-2016 02:22 PM
