kuryakyn or HD forward controls?
Old Feb 20, 2008 | 04:38 PM
ninetyzero's Avatar
ninetyzero
Default kuryakyn or HD forward controls?
I got a low rider and want to dump the mid controls. They give me cramps using them, and want to just go straight up forwards.
Anyone had a good experience with either of these? What is the difference in them, why is Harley's about $70 cheaper than kuryakyns?
Also, does either kit come with an item to put in the primary side where the foot peg is, to fill in that hole?
THANKS!!!!!!!
Old Feb 20, 2008 | 04:49 PM
WildBillAce2's Avatar
WildBillAce2
Default RE: kuryakyn or HD forward controls?
I like my Kury's. They didn't come with the extras to fill in the primary gap, but came with a cap for the original shifter. It doesn't look bad with the chrome cap, but if you want to take that out you can get a cover from HD for about 20 bucks.
Old Feb 20, 2008 | 06:19 PM
JayFromPa's Avatar
JayFromPa
The Kurys are chromed and I don't believe the HD ones are. The Kury's look better overall IMO also.
As far as the original shifter shaft goes, just cut it off and pop a small freeze plug into place. This also looks much better than putting the butt ugly chrome plug over the old shaft.
Old Feb 20, 2008 | 06:27 PM
vladt's Avatar
vladt
I have the HD and it's awesome. The fit and finish are first class and most parts are chromed.
Comes with every single bolt/nut/washer/gaskets and detailed instruction.
If you going to take the original shift rod out, I definitely suggest HD.
Old Feb 20, 2008 | 10:08 PM
70mach1's Avatar
70mach1
After a lot of looking and searching ,I ordered a set of Kurys for my 2007 Low Rider .
Everthing I here abought them is good ...
It may be a while before I install them do to snow and single diget temps .
I got them off e-bay , new in box should be here in a week or so .
$291.95 delivered...
[IMG]local://upfiles/12373/E0D600722C5F4045ABE9F2FF8BCAD926.jpg[/IMG]
Old Feb 21, 2008 | 06:45 AM
dyna07custom's Avatar
dyna07custom
Good thing about kury is it is easy to return them to mids if you sell
Old Feb 21, 2008 | 09:13 AM
Zevron's Avatar
Zevron
I went with the Harley ones. I am happy with them.
Old Feb 21, 2008 | 09:17 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: ninetyzero
THANKS!!!!!!!
Here's my 2 cents. The Kury's retail for $399. Don't pay that because you can get them at least 100 bucks cheaper online. I bought mine over a year ago from Eastern Performance via ebay for $299 shipped. I don't know the retail on the HD kit so I don't know how the prices compare with the discount on the Kury's.
The reasons I chose the Kury set are as follows:
- To me, they looked beefier and "blingier" than the HD setup.
- They are easier to install because they don't require removal of the primary cover. Just use the supplied locking clip to hideway the mid-shifter linkage point and put a chrome cap over the old spline. While I might be willing to try and install the HD kit today, I wouldn't have felt comfortable doing it back then and the HD kit would have been much more expensive after paying for labor to have it installed.
- They are much easier to remove and go back to mid-shift. I don't need or want to ever do this. However, if I ever sell my bike, the buyer may want mid-controls. Since none of the mid-shift components were removed, this can ben done quickly and easily and I don't lose a buyer because of forward controls.
I assume you've probably seen the Kury's. Here are some pix to try and show how they look installed. Perhaps someone can post some of a HD setup so you can compare. You really can't go wrong either way.
[IMG]local://upfiles/41150/27E9A0FD2F62493797DD3CCF5BEF0870.jpg[/IMG]
[IMG]local://upfiles/41150/B6B08B6DC18647C5B58FB3DC14C214DF.jpg[/IMG]
[IMG]local://upfiles/41150/95C4318669F14A3D94414FA77A44BD68.jpg[/IMG]
[IMG]local://upfiles/41150/2A97741E4F8E4A1782AEFA3E7D08F9C8.jpg[/IMG]
[IMG]local://upfiles/41150/BBDAF8BA73434DAABAC0F3EABCAD9EE2.jpg[/IMG]
Old Feb 21, 2008 | 10:00 AM
dyna07custom
ORIGINAL: 70mach1
same thing I paid only takes about 2 hours to do
Old Feb 21, 2008 | 11:25 AM
sniper77's Avatar
sniper77
I have the HDs and after looking at some of the detail above, I like the Kurys better but won't be changing mine out for the small difference in the mount design.
