How to mount the HD fork bag?
Old Apr 1, 2008 | 12:08 PM
bobby5's Avatar
bobby5
Default How to mount the HD fork bag?
How do you guys mount the fork bag on the front? Mines a Harley one i put it on but there is those leather strings danglin everywhere? You suppose to tie those around the forks or let them dangle? Anybody have any pics?
Old Apr 1, 2008 | 12:11 PM
evansf_fde's Avatar
evansf_fde
Default RE: How to mount the HD fork bag?
I did not use a Harley fork bag but I was able to tuck the excess inside of the bag...
Old Apr 1, 2008 | 01:20 PM
shimmon's Avatar
shimmon
i have a harley forkbag. mine does not have strings... if so i would cut them off. i mounted mine below the headlamp.the buckle end is short and goes just past the left tube of the fork on the back side. the other end goes around back of the right tube, then in front of the headlamp mounting bracket. and buckles behind the bag and i tuck the excess strap in front of the headlamp mounting bracket... if you can fallow what i said...
Old Apr 1, 2008 | 01:48 PM
rh8234's Avatar
rh8234
My HD bag had two leather straps that you were supposed to wrap around the fork tubes. They were worthless, so I tossed the straps and used two "supersized" zip ties. They are about 1/2 inch wide. Threaded them thru the slots in the back of the bag where the leather straps had been and zipped them to the fork tubes. 4 years later, they are working fine.
Old Apr 1, 2008 | 01:50 PM
JRK5892's Avatar
JRK5892
I also use SUPER size ZIP ties... i dont like it to move around... my radio is in there!
Old Apr 1, 2008 | 01:51 PM
2008FLHP's Avatar
2008FLHP
zip ties and duct tape will get you through life!
Old Apr 1, 2008 | 01:55 PM
Hutson's Avatar
Hutson
ORIGINAL: 2003FLHPI
aint that the truth, and lets not forget about super glue!
Old Apr 1, 2008 | 01:56 PM
07bobber's Avatar
07bobber
LIKE MINE? LOOK AT SIG
Old Apr 1, 2008 | 02:11 PM
kk6pg's Avatar
kk6pg
bobber,
Yours looks good flappin in the breeze.
I didnt like the ones out there so I made my own. Rather than have the leather strap and buckles, I used black latigo lace and tied it off inside the bag. It was either that or zip ties.
Now, if someone makes a chrome zip tie.......
Old Apr 1, 2008 | 02:17 PM
tbone52's Avatar
tbone52
One strap threaded through the bag. Behind the left fork, in front of the headlight mount, behind the right fork (being careful to not put it around the flexible brake line - you'll bend the crap out of it when you tighten it - don't ask me how I know) buckle on the outside of the right fork and thread excess into slit in bag. No pics available. I take mine off when I wash so I wouldn't like the zip ties unless they can be removed easily.
