hers a good one from another brd
1. Blew oil out of Primary 1st day<o
></o
2. Kick stand spring lost on highway 1st day<o
></o
3. Clutch cable leaking oil (Replaced #3-#4 times) 1st day<o
></o
4. Front End wobbles (has never been corrected) 1st day<o
></o
5. Can not let go of handle bars 1st day<o
></o
6. Speedometer fogging up 1st day for (7-10 days at a time) (2 speeding tickets @ 80mph) (Eventually they replaced)<o
></o
7. Lock on front forks fell loose and bent<o
></o
8. Ignition switch difficult to turn (bent key)<o
></o
9. Bike would not crank-electrical problems<o
></o
10. Alarm keeps going haywire<o
></o
11. Will not go into trailer mode (Dealership pulled main fuse)<o
></o
12. Replaced ignition switch but they wired it in wrong<o
></o
13. Continues to have difficulty turning keys (even after being replaced)<o
></o
14. Key and fob fell out while driving (switch went into accessory mode)<o
></o
15. Breather fell off while driving down highway
16. Upper bolt on shock sheared off<o
></o
17. Continues to eat up front tires @ 4-5 thousand miles (has never been corrected)<o
></o
18. Key fobs would not engage and dis-engage properly<o
></o
19. Motor/Starter making klunking noise while cranking<o
></o
20. Weld broke on muffler support bracket<o
></o
21. <st1
lace w:st="on">Cam</st1
lace> and bearings knocking (Replaced)<o
></o
22. Transmission went out (Replaced)<o
></o
23. Bike started rattling real bad at low speeds<o
></o
24. Difficult shifting (Hard shifting)<o
></o
25. difficulty locating neutral @ (Red lights, and parked mode)<o
></o
26. Saddlebags strap and buckle broke (both Leak water)<o
></o
27. Primary cover gets extremely hot within a couple of miles
28. Primary blew oil out again (3rd time)
29. Cupping front tires (53,000 miles and have replaced front tire 7-10 times)
30. Front end wobble still exist
31. Makes Klunking noise on start up intermittingly (sounds like flywheel has teeth knocked off) (slow starting)
32. I have had a lot of more issues but I did not document as I travel so much it is difficult
this is on a 97 dyna lowrider with 53000 miles
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
>21. <st1
></o
></o
></o
></o
></o
></o
Rockitdude
Apr 8, 2019 03:27 PM
Longshot USMC
Jul 20, 2015 09:54 AM
