Aux lights
Old Nov 23, 2008 | 08:11 PM
mgw750's Avatar
mgw750
Default Aux lights
Can any one recommend aux lights? planning on mounting them on a 2009 lowrider. The stock light is really weak. Im going to mount a crash bar on the bike and plan on mounting the lights to it. I have piaa lights on another bike and they work very well. Is there any out there that work as well as the piaa's but have a little more style. I have seen some but worried that there more style then function. What do you think about mounting on a crash bar vs a light bar which oddly enough I havnt found.
Old Nov 23, 2008 | 09:12 PM
rewog's Avatar
rewog
I have an 07 LR with a Linby and added the HD foglights which worked really well, but it just didn't look right, so replaced them with Kuryakyn Silver Bullets(20w ea.) to no avail. Kury does have some new "Constellation" driving lights, however you'd have to work at mounting them to a crash bar. Sylvania does have an H4 direct replacement for the headlight that is noticebly brighter.
Old Nov 23, 2008 | 10:20 PM
archergodwin's Avatar
archergodwin
The stock light on my 08 SG is bright as hell..... but I would probably go with Sylvania Ultra Silver Star as a replacement for the stock bulb. That should give ya all the light you need. You should only expect about a 6-7 month life span out of the bulb though.
Old Nov 23, 2008 | 11:25 PM
JRK5892's Avatar
JRK5892
got a set of bullets... mounted them under my trees by tapping and drilling them in...bright as hell!
Old Nov 24, 2008 | 04:07 PM
mgw750's Avatar
mgw750
Never thought about changing the bulb (brain fade). I will change that but will still add aux lights. The linby bar is what I would like to use. On the other bike I drilled the bar and used rubber gromets and ran the wire through the bar, cant stand wires hangin in the breeze. I will check those lights you all recommend. Thanks
Old Nov 24, 2008 | 04:32 PM
JRK5892's Avatar
JRK5892
here is a great thread on it
https://www.hdforums.com/m_3549132/tm.htm
Fatboy103
Feb 25, 2013 05:55 PM
AmericanMuscle
Jul 3, 2012 09:10 AM
outlaw0013
Mar 30, 2010 12:08 PM
jimsreddyna
Jun 27, 2008 06:04 PM
siramazing
May 12, 2007 05:55 PM
