What kind of jack is this?
UPDATE!! I found the forum member that had the jack (efciv) !!! Here is the link http://www.heindlengineering.com/Onl...iser_Stand.htm
I saw this on the forum and can's seem to find it online?
Thanks,
J
Thanks,
J
had the same problem with my lowrider. I just put 2 pieces of 2x8 on the ground( one for the front tire and one for the rear) and drive the bike on, slide the jack under and your good to go. I like what youve done with the bike,BTW.
I just bought a jack/lift from Harbor Freight. I haven't taken it out of the box yet, but looking under my bike, I can see it will be somewhat of a problem, as the bottom isn't flat on a WG. I suspect I'll have to do some mods to the jack to make it work. Any othe Dyna owners already done this? What did you use?
Ahhh yes! The Dyna Adapter! Why didn't I think of that?
Doesn't seem to be something harbor freight carries. I thought it might be jack specific, but, a Google search turned up a Dyna Adapter kit from J&P Cycles. I also found HD has a similar kit available. The most unusual thing I learned, is the HD kit is cheaper than the kit from J&P Cycles. When the hell has that ever happened before? Is this one of the signs of the apocalypse?
I was thinking of just using some 2x4's or something. Is having plastic blocks somehow better?
