Winter and battery care
Well in New Hampshire winter is here. Ice and snow on the roads, only a person with heated clothes and perhaps a screw loose would be riding today ... IMO! (Even if your warm ice is ice) Sooo question ... If you live in my type of climate do you always remove the battery from your bike during the winter? The reason I ask is this is my 1st Harley but I've owned several Hondas, Yamahas, one BMW, one Triumph (Been riding around 15 years) and I've never taken out their batteries during the winter ... never. Also ... so far not ONE motorcycle has failed to start for me in the spring. They crank a little longer the 1st time they start in the spring but ALL have started and knock on wood I've yet to have a battery die on me. (I normally only keep a motorcycle for a few summers before buying a different one so the batteries don't tend to get too old.)
I've read suggestions about taking out the battery, placing it on a trickle charge all winter, not placing it on cement, etc. but my experience has been good leaving it on the bike all winter and simply hitting the starter in the spring.
So is it STRONGLY suggested the battery be babied over the winter (for some special reason connected to the quirks of a HD motorcycle) or is it just "the company line?" What's YOUR experience been?
BTW my bike is in a non-heated garage, covered and the alarm system is still on.
When the battery is hooked up it can drain the battery. In the Antarctic and for my own vehicles I will at least disconnect the battery while parked for a long period of time. Generally with my bikes I remove battery and keep in my basement on wood in case they decide to leak. My 06 WG that I bought 9/05 is still on OE battery. I do not use a battery tender.
So you simply disconnect the battery and keep it from freezing. Thanks for the advice!
I've always run Odyssey gel batteries in my bikes and I always left them connected to the bike and unattended through the Wisconsin winter months. The batteries start out around 12.7 volts and by the time the winter is over they are generally right around 12.5 volts.
I recently purchased a Honda and threw a cheap *** battery in it because it's the beater of the stable and I won't be keeping it long enough to justify a gel battery. That battery is in the basement on a wood shelf. I've heard if you leave a battery on concrete it'll drain it out. I'm looking to purchase a battery tender for it and future use.
I've heard that about concrete too. I may take my battery out ... it depends on the weather. Right now it's 14 degrees and windy ... even in my garage it's too cold to deal with taking off the seat, etc. etc. When it gets above freezing again maybe i'll take the battery in. ........... Hey the worse that will happen if i leave it the way it is is I'll need a battery or a charger come next spring ... right?
Take it out or leave it hooked to a battery tender in the bike The bike has parasitic amp draw and will run the battery down over storage. My bike is inside heated so I just leave the tender on it never a problem but if you are in unheated space I would pull and store inside, charge it a few times over the winter or hook to tender this will prolong battery life. if you leave on concrete just put a piece of carpet or wood down
