A seemingly stupid, but poignant question about fuel management systems
So is it even worth the money of doing stage one if I am just going to swap out the fuel management system? I know I want one, not sure which, but I don't want to pay for something needless. Sigh... even as I type this I know the answer, but for the sake of some people that don't.
Thanks for humoring me.
Lancer
Lancer
Swap out the fuel mgmt system? I don't follow. Fuel management for stage 1 augments/adjusts your ECM fuel managment to offset the additional air flow in and out due to the upgraded intake and exhaust. Nothing is swapped out. Depending on the device, you would plug it into your existing system, tune the ECM (i.e. SERT), or you actually plug the device in-line permanently (i.e. fuelpak, PCIII).
There's nothing needless about it. Your bike is tuned on the lean side to begin with by the factory to comply with EPA regs. If you add stage 1 components, you likely will overlean the bike and it will not be running properly and could even do long term damage. You need some sort of upload/download or device to tune the ECM to deliver the right amount of fuel to mix with the additional air flow.
When you are referring to Stage One, are you speaking of exhaust, air cleaner, and the Stage One download by the dealer?
If so, the only advantage to the download, if you also plan on installing a fuel management system, is the download will act as a back up. Most your fuel management systems trick the ECM to make it deliver more fuel. If the fuel management system fails to work, you are back to running too lean of a fuel mixture and may not even know it. If you have the download and your fuel management fails, the download will help protect against the too lean condition.
Normally people will use one or the other, not both.
Has anyone ever done this? What are your likes/dislikes?
Lancer
I have a SERT and it works fine for me. But I would advise you to check out 3 systems before you buy.
1. SEST (new model of the SERT)
2. TTS Mastertune -find Steve Cole and ask him
3. Thundermax- lots of users on here.
Good luck.
