Secondary drive belt tension
The drive belt on my 2009 Street Bob is slightly loose. According to the service manual, it should deflect 1/4" - 5/16" when tested at 10# using the H-D tool. I measured 5/8", so I'm going to adjust it.
My question concerns checking the rear wheel alignment after setting belt tension. The part about using 1/8" wire (welding rod, coat hanger, etc.) with a movable o-ring to verify the tire is aligned in the swingarm is intuitively obvious, but the other procedure is not (at least, to me). How important is the second part of the procedure, given that all I'm doing is loosening the axle nut and adjusting the belt tensioners? As long as I take up the same amount on each nut, then use the wire to verify the tire is aligned in the swingarm, I'd think that should be adequate.
Looking forward to hearing from you experienced wrenches out there. Thanks in advance!
You can check wheel alignment several ways. You can simply use your eyes, a piece of string, a cheap laser (diy tool), or a straight plank of wood, or strip of metal (they must be straight!).
With the plank or metal, prop it up alongside the bike on blocks, so it is as high up the rear wheel as practical, touching at both front and rear edges of the tread. Turn the front wheel to its best position, taking into account that it may be narrower than the rear. You can move the plank and blocks to the other side to compare results. Alter the adjusters to give the same results both sides.
With practice you can simply look along the bike, or use a length of string or a laser to do the same job as the plank.
If you google 'bike wheel alignment' you will get several articles giving more details.
