How to clean cyclendr cooling fins
#81
Best I came up with to clean and brighten the machined faces of the engine fins is scotchbrite pad soaked in vinegar. Do one fin at a time and rub with gentle easy pressure so you don't wrap the Scotchbrite over onto the black powder coat and take you time. This is a couple hour kind of cleaning job but well worth it.
#82
I bought a fine hobby file set, they are relatively small for getting into tight spots and the set comes with all sorts of angles on them. I did each fin individually and they look great. I used the files because I thought the use of any sandpaper was going to round out the edges and I wanted them to keep the sharpness. Once the metal is pitted, it's the only way to get enough material off to make them look new again.
Steve
Steve
#83
