Front turn signal bracket
Hey I bought those swivel brackets from J&P to go on my wifes 79 low rider, but all be damed if I can't figure out how to mount em up. I know they drop off the bottom of the mirrors, but which end goes what way, and I know this sounds dumb, but how do I tighten up the swivel? Could sombody send or post a close up picture of their front turn signal mounts?
thanks,
sorry about the stupid questions
pat
imboden2@netzero.net
thanks,
pat
The brake side and the clutch side are different. The clutc side has a liitle offset piece that lets the assembly clear the clutch lever and mechanism you use your existing mirror nut to hold this piece on. The brake side looses the mirror nut, first replace the mirror nut with the chrome nut from the kit then proceed with the swivel nut. You'll notice the swivel will confortably fit inside the swivel nut. The swivel will tighten up to the angle you select as you tighten the swivel nut, just make sure you hold the angle you want as you start to tighten things up.
thanks for the tip, got it figured out tonight and I'm all set. all I'm waitin for now are the bullet lights to come in the mail!! Course I'll put up some pics when I'm done.
thanks again,
pat
thanks again,
pat
