Gotta Ask
Old Jul 28, 2009 | 01:33 PM
wolfprint's Avatar
wolfprint
Default Gotta Ask
Lost the cam chain tensioner after 55,000 so told them to put in new rings when they tore it apart. Got it back, ran beautiful, took it back after 500 miles and they put the Royal Purple synthetic in. Started burning oil at about 1-qt. every 500 miles. Smoked a little, they asked me to give it a little time. Gave it until 3,000 mi. Was going on a trip anyway. Got back and still smoking so took it back and had them break it down, inside cylinders were like glass. The synthetic had leaked through the rings. Have put new rings in honed it again hope that will take care of it, anybody else have the unfortunate problem.
Old Jul 28, 2009 | 05:59 PM
outback2970's Avatar
outback2970
Never experienced it first hand, but have heard syn oil getting blamed for "the never seating rings" when used from day one a few times.
Old Jul 28, 2009 | 06:21 PM
SC-Longhair's Avatar
SC-Longhair
Man that's gotta suck. At least it wasn't worse and you're still riding.
Old Jul 28, 2009 | 08:48 PM
NoLongerAmember's Avatar
NoLongerAmember
Did they hone/de-glaze the cylinders the first time, if they did not there you are and if they did are the bores out of tolerance? 500 miles should have seated the rings if the cylinder was prepped right. Kind of sounds as if you should have went with an over bore kit, etc. I hope it works out for you the 2nd time around.
CB
Old Jul 28, 2009 | 08:59 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I use syn3 to break in my bikes because it is a groupIII dino synthetic. I run it until about 1000-1500 miles changing it out a couple of times. Never an issue. Redline says NOT to use their oil until 3000 miles for this very reason.
Bingee
Engine Mechanical Topics
Mar 24, 2015 03:28 PM
goldie
Aug 6, 2014 12:24 PM
FATBOB.
May 2, 2010 12:03 PM
moderndaydrifter
Feb 27, 2008 07:43 AM
moderndaydrifter
Exhaust System Topics
Feb 26, 2008 11:19 PM
